Keyster carb kits
Posted: Thu Nov 28, 2013 8:44 am
by pertrx850
Hi!
Has anyone used the Keyster carb kits? (rebuild kit including emulsion tubes, jes etc.)
If so, are they good?
Thanks!
Regards,
Per
Re: Keyster carb kits
Posted: Thu Nov 28, 2013 10:46 am
by alextrx850
If it is the Keyster KY - 0570 kit then it's a good kit.
Most of us around Brisbane have the kit and is good quality with value....
Advise fitting the needle clip itself in the lower notch instead of the middle as you would....three notches to the needle I believe....can be a little lean otherwise.
Yep..a good fit up.
Posted: Thu Nov 28, 2013 5:35 pm
by pertrx850
Thanks!
Regards,
Per
Posted: Fri Jan 03, 2014 11:46 pm
by pertrx850
Ordered and fitted (partly)! Seems to work fine when running it outside the garage. Longin for spring already
Posted: Sat Mar 08, 2014 9:29 am
by jerrah
Where did these people of Brisbane purchase their Keyster carb kits?
Posted: Sat Mar 08, 2014 10:05 am
by alextrx850
They were advertised on e-Bay..vendor was in Australia which was handy.
Posted: Sun Mar 09, 2014 11:10 am
by Con Rod
Posted: Sun Mar 09, 2014 12:58 pm
by Trixed
I bought it from the above workshop in person. They were very helpful and professional. Works really well on the TRX.
Recommend the kit.
