Power increase
martyboy848
Power increase
Post by martyboy848 » Sun Jan 24, 2021 11:13 pm
I have a TRX850 with short carbon Scorpion cans, I bought a ported and polished head, if I fit it with stage 1 or 2 dynojet what sort of power increase can I expect?
jpe70
Re: Power increase
Post by jpe70 » Mon Jan 25, 2021 8:14 pm
Fit the worked head, but don't fall for Dynojet crap (at least for this bike). Rejet with Mikuni parts in a bench and you might see 5 extra. Fit some aftermarket oversize downpipes and you get 3-5 more. Slipon is mostly for noice... ;)
Get som flatslide carbs and you add another 5-10 hp and with hi comp pistons to round off the package you'll get close to 100.
Better usable power will be the main gain from the flowed head alone.
Ahhh, crap. I don't know, this is guesstimates.
Re: Power increase
Post by dicky » Tue Jan 26, 2021 2:26 am
As it is, you probably won't notice anything except noise and maybe a horrible dead spot around 4k rpm.
Replacing the stock ignition unit with a Ignitech gets rid of the dead spot and allows for custom mapping, well worth the money.
As already stated, most carb kits for TRX's are crap as they come from the USA which never had the TRX, so what you get is a TDM kit.
CV carbs can be set up to work very well, but you need a good needle profile and the right sized main jet, which is harder than it sounds to get right.
The stock Yamaha needle is quite good, the standard mains are usually too big.
With otherwise stock carbs and headers, the flowed head has the same inlet and outlet restrictions, so you won't see any appreciable gains.
With bigger exhaust headers and bigger flatslide carbs (FCR/TMR) you start to get something you can feel, but flatslides are even harder to set up correctly than CV's.
Performance Bikes built a hot TRX way back in 1999 and they got 92hp at the rear wheel. 1mm oversize pistons, 13:1 compression (up from 10.5), FCR41's, ported and volume matched head. Quite a lot of work.
Not much has changed since then, just harder to get parts.
kenbev
Re: Power increase
Post by kenbev » Wed Jan 27, 2021 12:11 am
=D> Why go to all that just to get a little bit more power, why not just enjoy the TRX for what it is and buy some thing with the power you want. Leave well enough alone and just enjoy the hell out of a great bike. My thoughts. Kenbev.
Re: Power increase
Post by dicky » Wed Jan 27, 2021 10:59 am
I've nothing against anyone who wants to work over the TRX and get every last bit of performance out of it.
Cobba has kept us all amused for years with his epic endeavour to build an Over Racing spec bike, and he bloody well did it!
Quantime did a similar amount of work many years earlier, as did Honkdawillydahonk and he got his bike written up in PB!
What should be quite clear, and it was never a secret to begin with, is that making the bike stop better, turn better, and weigh less, is equally important as getting more power if you want to go faster.
Blue spot brakes, cartridge, emulator or USD forks, and lighter wheels make more difference than 10hp, and probably costs less too.
spiritedride
Re: Power increase
Post by spiritedride » Wed Jan 27, 2021 9:53 pm
Hi Kenbev,The trouble for me was that I liked every aspect of the TRX apart from its power output.I went looking for higher hp bikes but found nothing that I liked better than the TRX’s design and how it rode.Decided to go down the “ EXTERNAL” engine mods and “ INTERNAL” suspension mods path to wake up the motor and improve the bikes composure,Flatslides,Free flowing cans and Programmable ignition certainly woke up the motor with instant throttle response from 3000 rpm in any gear and the 9000 rev ceiling let you hold a gear between corners better.Cost more than half of the bikes value but it is why I still own it. Cheers.
Red Rex
Re: Power increase
Post by Red Rex » Thu Feb 25, 2021 9:03 am
One way to get more performance out of your TRX (or any other bike for that matter) is to reduce the visit to McDonalds and KFC.
… or upgrade the brakes. (Most overtaking gets done on the brakes going into corners than powering past on the straight bits :D )
Richie
Re: Power increase
Post by Richie » Tue Jun 25, 2024 7:41 am
Bumping this thread to keep info in one place.
And hello, new to the forum here 👍
People often mention larger diameter downpipes but there is never any size given. Can anyone remember what size we're shooting for?
HolerTogni
Re: Power increase
Post by HolerTogni » Tue Jun 25, 2024 1:24 pm
Hi Richie!
First: Welcome to the forum - have fun here and in the real world!
Second: There must be (plenty of) data here but I found a thread about a selfmade downpipe in the German forum that 40 mm diameter will work - with an respectively adapted outlet, of course.
That said, the diy downpipe had changing diameters (40 - 45 - 50) and the hole project is not that easy.
However, if you are an experienced builder of downpipes, there should be no problem.
Informing greets from Munich!
PS:
How about introducing yourself a little in the respective section here?
Would be nice.
