Tarwetijgers Winter Works
andyaber
Re: Tarwetijgers Winter Works
Post by andyaber » Sun Feb 23, 2014 11:52 am
A bolt is only threaded for part of it's length, whilst the thread on a screw continues all the way to the head.
Post by cobbadiggabuddyblooo » Sun Feb 23, 2014 1:00 pm
bingo.. we have a winner..
Double or nothing ..
So why not just thread all bolts to the head and just call them screws.. :scratch:
andyaber
Post by andyaber » Sun Feb 23, 2014 6:49 pm
Long time ago now but is it issues with fit and strength where a bolt passes through 2 plain holes and into a nut and a screw is more general purpose often into a threaded hole?
Also if you are making a million bolts it's quicker and cheaper just to thread the necessary part rather than the whole length.
I do remember the maxim 'every nut deserves a washer'.
Cheers, Andy.
bubbaad
Post by bubbaad » Sun Feb 23, 2014 11:09 pm
Not all screws are threaded all the way,,,,,,A tomato isn't really a fruit,,,,,we all know that.............
andyaber
Post by andyaber » Mon Feb 24, 2014 12:00 am
Would the tomato pip be the true fruit?
NWS870R
Post by NWS870R » Mon Feb 24, 2014 1:32 am
They are called 'set pins' not screws!! :roll:
Rod.s
Post by Rod.s » Wed Feb 26, 2014 12:38 pm
A bolt is if she's under 18 and a screw is if she's over 18, simples….. :D
Post by dandywarhol » Wed Feb 26, 2014 7:55 pm
NWS870R wrote:They are called 'set pins' not screws!! :roll:
Setscrew in my world :D
NWS870R
Post by NWS870R » Wed Feb 26, 2014 7:55 pm
:lol: =D>
Rod.s
Post by Rod.s » Wed Feb 26, 2014 11:44 pm
Set screws are not bolts :roll: :lol: and are only used to secure an item to a shaft or spline, the tip/cone of the set screw bites into the shaft for a tight fit :D
Post by dandywarhol » Thu Feb 27, 2014 1:06 am
Rod.s wrote:Set screws are not bolts :roll: :lol: and are only used to secure an item to a shaft or spline, the tip/cone of the set screw bites into the shaft for a tight fit :D
Interesting but not where I come from. What you talk about Rod is a grubscrew up here
A setscrew is threaded to the end a bolt isn't. 8)
Rod.s
Post by Rod.s » Thu Feb 27, 2014 1:21 am
Yep, there are often two "correct" names for an item, one being the engineering name and one the common name. Set Screw is the correct engineering name and Grub Screw (because it looks like a small grub) is the common name :D
Edit, I've also hear them called "blind head screws" 8-[
Rod.s
Post by Rod.s » Thu Feb 27, 2014 1:28 am
Another fun one is, what are these called :D
Gordo
Post by Gordo » Thu Feb 27, 2014 2:37 am
I always call them dome nuts. I do remember my late Father (an engineer), once informed me the proper name is a "crown hex" nut. Close? :dontknow:
Gordo-
Post by dandywarhol » Thu Feb 27, 2014 9:02 am
Painful butt plug?
