Quickshifter
danno
Quickshifter
Are quickshifters available for the TRX850 or are they only designed for fuel injected bikes?
Re: Quickshifter
You could by a mechanical QS and refit a TCIP4 from ignitech, it has kill input.danno wrote:Are quickshifters available for the TRX850 or are they only designed for fuel injected bikes?
I have one in the garage but haven´t bothered as i´ve heard they can be a betch getting setup correct.
...i´m also quick enough
- Con Rod
Re: Quickshifter
The TRX box is pretty slick and will happily allow you to upshift without the clutch,
that said i recently rode a Daytona 675 with one and it was pretty nice
Dan 850
Re: Quickshifter
They do make them for carb'd bikes I'm in the process of buying one because my gearbox has shat itself on my gsxr through harsh up shifts on track. Look up "translogic quickshifters" they look good, guess they are a bit pricey. Found a chap who could do a full kit for £300inc vat though
Double the fun if your riding twins! Shame her sister doesn't think so.
BigAl-TC
Re: Quickshifter
I was going to try this mob, but haven't as yet.
www.bikeshifter.com/quickshifter.htm
Have a look and let us know what you think.
Alan.
Alan.
danno
Re: Quickshifter
Hmmm, I don't know enough about these type of things, but the website for some reason, look a bit dodgy. There is another more recent thread that has a bit more infoBigAl-TC wrote:I was going to try this mob, but haven't as yet.
http://www.bikeshifter.com/quickshifter.htm
http://www.trx850.com/phpBB_forum/viewt ... =6&t=10449
Re: Quickshifter
Neither my TRX or TDM box allowed me to shift with full throttle....made wrong?Con Rod wrote:The TRX box is pretty slick and will happily allow you to upshift without the clutch,
- Con Rod
Re: Quickshifter
Yes, this is true, but just back off slightly and momentarily and click up, no clutchKillerwhale wrote:Neither my TRX or TDM box allowed me to shift with full throttle....made wrong?Con Rod wrote:The TRX box is pretty slick and will happily allow you to upshift without the clutch,
Re: Quickshifter
That´s the thing with a shifter, no backing off.Con Rod wrote:Yes, this is true, but just back off slightly and momentarily and click up, no clutchKillerwhale wrote:Neither my TRX or TDM box allowed me to shift with full throttle....made wrong?Con Rod wrote:The TRX box is pretty slick and will happily allow you to upshift without the clutch,
And really, even if i did what you suggest it felt like the motors where gonna crasch!
Now smoother than my butt after sleeping in butter for a week....
Re: Quickshifter
Wire the kill switch through the horn button - just press the button as you upshift
Used it on most of my race bikes in the 80s
