Fitting R6 Front Brake Calipers
Tealman
Hi guys. I'm about to hit the button on a pair of R6 (2002) front brake calipers and master cylinder - I know that this is a recognised upgrade for the TRX but can someone confirm that it's a straightforward 'bolt on' upgrade
Re: Fitting R6 Front Brake Calipers
Confirmed.
All non-radial calipers from R1 & R6 bolt straight on.
You should use use the R1 or R6 brake master cylinder as well, this gives the correct 'feel'.
- Con Rod
there is some re-routing of the brake lines, but you can make the stock lines work fine
Tealman
Many thanks for the info chaps - I'm using the R6 master cylinder too. Parts are now on their way
