Has anyone done or seen a TRX converted to right hand gear change?
I'm going to do this so I'd be interested in seeing any pics. I think the easiest option is through the swinging arm spindle.
Right hand gear change
Re: Right hand gear change
The gear shift shaft goes all the way through to the other side of the motor and can be seen when you remove the clutch cover . You can see the gear selector drum in there.
atreyu
Are you suggesting extend the shaft through the clutch cover? It would be neat but would require a boss welding onto the clutch cover with an oil seal?
