5sl Master Cylinder
ryancas91
5sl Master Cylinder
Post by ryancas91 » Tue Dec 15, 2020 12:02 pm
Hi All
been reading up on the blue spot upgrade but im getting confused over what front master cylinder i need, i no i need one that has 14 on it but i keep finding two different types, can someone please confirm below which one i need from these two links thanks.
https://www.ebay.co.uk/itm/YAMAHA-YZF-R ... %7Ciid%3A1
https://www.ebay.co.uk/itm/YAMAHA-MT07- ... 1438.l2649
jpe70
Re: 5sl Master Cylinder
Post by jpe70 » Sun Dec 20, 2020 4:19 pm
You need the one that comes with the calipers, so just get a complete set. Easy. Otherwise from any R1 98-02 or similar aged R6 will work. 14 mm as you say.
The difference between the two you linked are just how they handle the brake fluid. MT07 have a big, square built-in tank. The R1 have a remote reservoir. You should get the later.
ryancas91
Post by ryancas91 » Mon Dec 21, 2020 1:28 am
So i should get the one without the remote reservoir ?
Post by dicky » Mon Dec 21, 2020 4:18 am
You should get one with a remote reservoir, such as those from the R1/R6.
ryancas91
Post by ryancas91 » Mon Dec 21, 2020 10:43 am
thanks for input dicky, i no what to look for now
