Big Inlet and Exhaust Valves (+1mm)
Re: Big Inlet and Exhaust Valves (+1mm)
Post by Mincehead » Sun Nov 04, 2012 4:55 pm
Mark has already posted about the valves on the TDM forums too. :wink:
Post by Tarwetijger » Sun Nov 04, 2012 5:21 pm
Mincehead wrote:Mark has already posted about the valves on the TDM forums too. :wink:
Acknowledged!
So, posted on two dutch forums. :D
Post by Mincehead » Sun Nov 04, 2012 5:32 pm
=D> =D> =D>
Post by Killerwhale » Sun Nov 04, 2012 5:43 pm
Tarwetijger wrote:Okay, first: I'm interested in a set too. 8)
Then: If the valves remained the same over some models, these bigger-valves-set can also be used on TDM850 and TDM900's?
If yes, then the market is just getting bigger Sanddune51! :D
Read up that some dudes in OZ found 7,7HP on a scrambler 900 with minimal loss in low down tourque.
As i´ve won some dosh recently i´ll take a set...if poor gains i got fresh valves anyway!
Post by Mincehead » Sun Nov 04, 2012 6:25 pm
On the horses Kw? :wink:
Post by Killerwhale » Sun Nov 04, 2012 7:15 pm
Mincehead wrote:On the horses Kw? :wink:
1800£ on harnessracing yes 8)
Post by Mincehead » Sun Nov 04, 2012 11:29 pm
Very nice, I don`t do gambling in general, well apart from with my life when the red mist descends. :lol:
Kenny
Post by Kenny » Mon Nov 05, 2012 10:46 am
Are you porting your heads to old school spec or to the new way of thinking with high velocity smaller ports?
Post by Killerwhale » Mon Nov 05, 2012 11:32 am
Kenny wrote:Are you porting your heads to old school spec or to the new way of thinking with high velocity smaller ports?
Mine are vel ported on the exhaust side, full race port with piranha teeth in the inlet.
Post by sanddune51 » Mon Nov 05, 2012 2:18 pm
I've been away from my computer all weekend but am really pleased to see that things have really moved on.
Firstly a very big thankyou to "Tarwetijger" for posting a link to this thread on 2 Dutch forums =D> . That has already produced another taker from the Nederlands.
I can tell you all that we now have 9 sets of valves spoken for from all over the world 8),so it's a case of "when" and not "if" now. Thankyou to to everyone who has so far put their name down for a set.
Also thankyou to all those that have contributed to this interesting thread(don't stop). I hope perhaps in the future we'll have a lot head and port photos showing the ways people have modified their ports together with dyno results for different cams and compression ratios. :)
Ps. I'll come back to discuss Tdm900 valves shortly when I've collected the part numbers.As I understand it the 900's have the same generic part numbers but with revised suffix numbers. But, as has been mentioned before Tdm'ers don't generally tend modify their engines(unless they put them in "proper" Yamaha trellis frames :lol: )
Kenny
Post by Kenny » Mon Nov 05, 2012 5:07 pm
Same to sanddune51 please
Post by sanddune51 » Tue Nov 06, 2012 1:01 am
I have already ported my head using the same technique I use on all the heads I have ported. This did not include using "JB Weld" or similar on the floor of the ports to reduce the port diameter to speed up the gas velocity.
This technique seems to have a lot of merit,but I feel it would be too much of an experiment for me at this time.
Sorry. I had just duplicated the above
Fritz Trix
Post by Fritz Trix » Wed Nov 07, 2012 2:38 am
I'm also interested in a set
And i posted it in the german forum
Fritz
Post by sanddune51 » Wed Nov 07, 2012 4:07 pm
Fritz,
Thankyou for your interest,I'll add your name to the ever growing list, and thankyou also for putting out a shout on the German forum 8).
