Big Inlet and Exhaust Valves (+1mm)
johno440
Re: Big Inlet and Exhaust Valves (+1mm)
Post by johno440 » Fri Aug 02, 2013 2:26 am
Anyone finished the conversion yet and been able to compare before & after results?
Post by Killerwhale » Fri Aug 02, 2013 7:35 am
johno440 wrote:Anyone finished the conversion yet and been able to compare before & after results?
I wonder as well, or have you all put them up on the mantelpiece??
johno440
Post by johno440 » Fri Aug 02, 2013 7:40 am
Funny. I know cobba is rebuilding his as is using same engine builder I am, but yeah what about everyone else...
Post by cobbadiggabuddyblooo » Fri Aug 02, 2013 11:40 am
They said Rome wasn't built in a day and same goes for this mechanic...Maybe I should have invested my time And money on a property as the time I've been waiting for this rebuild I could have made a fortune on property sales at present :lol: :lol: at least I know the motor will be goin into a well tuned frame and suspension package now.
johno440
Post by johno440 » Thu Aug 15, 2013 4:46 am
Always the way when using a top quality guru. My 69 Valiant Hardtop been in shop now 2.5 years and mate who owns the business hasn't yet started. Made the mistake of telling him I wasn't in any hurry :?
Post by alextrx850 » Thu Aug 15, 2013 7:49 am
johno440 wrote:Always the way when using a top quality guru. My 69 Valiant Hardtop been in shop now 2.5 years and mate who owns the business hasn't yet started. Made the mistake of telling him I wasn't in any hurry :?
John, maybe you need a good panel beater that will have time for a project with that VE....or is it a VJ .?
Not many shops have time for the metalwork these days.
johno440
Post by johno440 » Thu Aug 15, 2013 9:24 am
Close, but no cigar :lol: It's a VF. I'm very anal and particular, everything has to be prefect (I blame the old man from being in the RAAF, only person I ever seen use a spirit level on every single paling whilst building a fence :shock: )
Not too fussed anyway, I know it's in good hands as owner of the shop is a mate and used to specialise in hot rod & harley custom spray jobs but now mainly does insurance work. My hardtop and another XA GT he has in the shop are afterwork projects :lol: Anyway I don't want to hijak this thread further, just appears as though the best pro's always seem to circulate via word of mouth, and yes you must wait in line :-({|=
Post by cobbadiggabuddyblooo » Thu Aug 15, 2013 10:44 am
After 3months of waiting for John Coonan ,he has had the spare head I have for the last month with only the springs taken off so far, so I've now elected to rebuild the bottom end myself with the help and guidence of Rod . By the time I finish that in a month or two I'm hoping he will have my head completed... Time for a bulk order on Carrillo Rods as Brett needs new Rods also so if anyone needs some the more the cheaper as they are a one off build as they dont keep them in stock...
johno440
Post by johno440 » Thu Aug 15, 2013 12:00 pm
Hey cobba you sure they're a one off build? Team Show & Go in South Aus says they have them in stock for $398 a piece. I put mine off when we had kiddy health problems earlier in the year after making the enquiry. However, If they are a one off I'd be in a group buy. I'll check with Team Show & Go tomorrow and let you know how I go.
Post by cobbadiggabuddyblooo » Thu Aug 15, 2013 12:11 pm
spoke to Carrillo directly and they gave me the contact for the Australian dist. it was about two mths ago I spoke to them and Aust $ has dropped 10c so I'll call again tomorrow to get an update on prices and availibility and timeframe...
spondontrx
Post by spondontrx » Fri Feb 28, 2014 5:25 pm
Hi , has anyone installed these valves in combination with a JE 868 piston kit ?
I am finally in the process of fitting these , but I am afraid the pistons have to be modified because of the valve pockets being to small for the bigger valves (not enough valve to piston clearance)
Post by sanddune51 » Fri Feb 28, 2014 6:09 pm
I'm really surprised to hear that you are having clearance issues. I skimmed my head by 0.035" and had no valve to piston problems. I used +1.00 mm Trx pistons and a std Yamaha head gasket.
Timing the cams in is a little fiddly and time consuming and easy to get wrong. If you do get it wrong a piston clouting an open valve is a very real possibility.
I'd be inclined to check and double check the timing using a large engine degree wheel and a dial test indicator. If you are getting contact stop and check why. I had contact whilst timing my cams because the chain had jumped over one of the sprockets #-o .
A dry build to measure and check whilst building an engine is invaluable.
Good luck with it, I'm sure you'll sort it.
Sorry I can't answer your question specifically as I used different pistons to you :(
spondontrx
Post by spondontrx » Fri Feb 28, 2014 7:41 pm
Thanks for answering , I'm not that worried about horizontal clearance (not checked it yet) but for the radial , the pocket space for the valves on the JE piston is quite deep and for instance the intake pocket is 26,4 mm in diameter while the bigger intake valve is 27 mm (opposed to the original 26) this is going to touch and destroy i'm afraid .
Off course this is something that can be solved , but I was wondering if there where more of you who came across this problem .
Post by Tarwetijger » Fri Feb 28, 2014 8:21 pm
This only accounts for the combination of JE pistons and the bigger valves.
Sanddune51 has original pistons, which are concaved on top.
And the pockets are wider (than strictly necessary) too.
See here for example:
The top of the JE pistons are round (higher in the middle).
The pockets seem to be the exact size of the original valves.
Misterdimwiddy has the JE pistons, but not the bigger valves.
Took a look at my stuff and yes, I think this is going to be a problem.
Mostly for the middle inlet valve:
original valve
bigger valve
Post by cobbadiggabuddyblooo » Sat Mar 01, 2014 2:14 am
Does anyone have the diameters of the larger valves???
I don't have the valves or the head at present ( :x :x ) to check them against the JE and Ross pistons I have.
The balancer can deal with any that may need to be machined out..
I agree with you Mark, it's benificial to have a dry rebuild to start and check all clearances beforehand and investing in a timing wheel and slotting the cam sprockets to get the timing exactly where you want it to suit the desired rpm/ output gains the motors being built to produce.
Valve timing being out just a few degrees can potentually rob you of all that work you put into to gain a little more.
Bit like if you grew your hands on your ankles and feet on your wrists. Sure you may have 2 hands and 2 feet but there sure was a timing issue involved there... :lol: :lol:
Not a good way to finally reach that 4 minute mile.... Let alone pick your nose
